[SOLVED] 24 pin cable stuck under drive bay
If you can't find any way to route the cable or move the drive bay, simply cut it off since you are replacing it. But it's very likely you just need to maneuver the cable around a bit, it is not likely they installed the power supply then built the case around the cable.
