[SOLVED] 24 pin connector stuck in mobo
Try to unlatch the 4 pin on it's own. Sometimes the plastic doesn't quite clear the clip. Sometimes it helps to push down gently, press the clip, then pull the connector.
You also can try with a hair dr
Try a hair dryer, you might be able to separate the connector while they are warm.
If there is a small gap between, you also can use a paper knife to pry it out, be careful to not damage the connector's edge.
Welp I don't have a proper hairdryer rn 😅
