[SOLVED] 2666MHz or 2400MHz?
TJ Hooker
Illustrious
Herald
I don't know if I've seen it referred to specifically as "DDRAM", but yes the effective speed/transfer rate is double the DRAM frequency (AKA memory clock).
Edit: You don't necessarily need to know all this when buying memory though. All memory is advertised by the effective (double) data rate. They usually list it in MHz, but it's equivalent to the double data rate MT/s being discussed here.
Reactions: Avik Basu
Endre
Great
Apr 30, 2019
179
19
85
So the double of DRAM, as in DDRAM, would be the whole frequency?
Starting with DDR1 up to DDR5, they are all Double Data Random Access Memories.
Which means that the advertized speed, incorrectly named MHz is actually MT/s.
The MHz are only the half of the MT/s.
Example DDR3-1600 means 800MHz x2, which means 1600MT/s (mega transfer per second).
In the SDRAM era MHz and MT/s were equal 100MHz meant 100 MT/s.
The PC that you have right now uses DDR3, if you’ll upgrade to DDR4, buy a memory kit rated DDR4-2933 or higher.
Endre
Great
Apr 30, 2019
179
19
85
@Endre you have your acronyms a bit mixed up. DDR1 through DDR4 (and beyond) is all SDRAM, which is Synchronous Dynamic Random Access Memory (sometimes the S is omitted, so just DRAM). The DDR stands for Double Data Rate. So the full name would be DDR[#] SDRAM. Hence why I said the specific acronym of "DDRAM" was one I hadn't seen before.
https://en.wikipedia.org/wiki/DDR_SDRAM
You are right!
Thank you for correcting me.
But my main point regarding MT/s vs MHz remains the same.
DMAN999
Respectable
Herald
Is there any good motherboard that won't require a BIOS update for Ryzen 3000 and isn't expensive?
Check the price of these in your area (they all support 3000 series CPU's out of the box):
B450-A PRO MAX
MSI B450 Gaming Plus MAX
MSI B450 Tomahawk MAX
Just Be aware that MSI does NOT have a good BIOS team, their BIOS updates tend to be buggy.
Reactions: TJ Hooker
Avik Basu
84
Gaming Plus MAX and Tomahawk MAX are available at a good price. There's no PRO MAX though. Just PRO. GP MAX and T MAX both say they are Ryzen 3 supporting in the specs. But I'm worried about the USB Ports. I can see at least 4 that look like USB ports, 2 of them red in color. And 2 that somewhat look like USB ports but not quite. They too are red in color. And MSI says Tomahawk (Max or non-Max, not specified) has a Type C USB but that's not visible in the pictures.
Is there any with in-built Bluetooth? Not mandatory but would be helpful. Don't even need in-built WiFi.
Correction - Tomahawk has 1 Type C USB port. But not sure about Tomahawk Max because I can't find any reviews on it.
Avik Basu
84
I see that. But look at the pic of the ports here. Type C is missing.
By the way, if it says on the box that the board is Ryzen 3000 ready that means I don't have to update the BIOS, right? Because it is bothering me that even though it doesn't say so in the specs on their own page Asus has still mentioned the B450-E to be Ryzen 3000 ready even though the pic of the box doesn't have that printed on it. So I was wondering if I should check about that with the store.
DMAN999
Respectable
Herald
Avik Basu
84
Oh, sorry, so sorry. Not even looking properly. A bit stressed out. Went from Intel to Ryzen to finding a board for Ryzen that can run it out of the box. I literally don't care about Type C USB since I don't have any device that uses it. I guess I'm bothered that there's one less Type A port. I know I can just use an add-on but I don't want to block the airflow space for the GPU.
I'll check with the store tomorrow and I'll also mail Asus tonight to see what they say.
How new is Ryzen 3000 that there are so few motherboards for it?
Avik Basu
84
Seriously? You bought one CPU so you can upgrade to another? Why not just wait a bit or get the BIOS updated from a store as you mentioned?
DMAN999
Respectable
Herald
The 3000 series CPU's were not released yet when I built my PC last November.
I actually planned on waiting until some time next year to upgrade but I had the extra money now, so I went for it.
Endre
Great
Apr 30, 2019
179
19
85
If you’re looking for a good motherboard, I suggest you checking out the Gigabyte Aorus lineup.
I can’t suggest an exact model.
I am on Intel platform with a Gigabyte Aorus Master mobo and it rocks!
Gigabyte works great with AMD too, they even broke speed records with an AMD Epyc CPU on a Gigabyte server motherboard.
Gigabyte excells at VRMs quality and they put out BIOS updates every 2 months, without them being buggy.
Avik Basu
84
I don't think getting a good motherboard is a problem. The problem is them working with Ryzen 3000 without needing a BIOS update. I actually wouldn't have minded going for Gigabyte. They have a good number of USB ports and my current board is Gigabyte too so I'm used to using it. But I have checked the Aorus lineup boards available in my budget and they have the same problem as pretty much everyone else. They are for Ryzen Gen 1 and 2 but will most likely work with 3 after a BIOS update.
@DMAN999 Asus hasn't replied yet but I have checked with the store and they said it'll need a BIOS update and that they'd do it for free. So now the question is should I get the Strix that needs a BIOS update and might get hiccups from it but I'm kinda leaning towards or should I got for the Tomahawk MAX that doesn't need a BIOS update so no need to interfere with that but has a bad BIOS team in case that becomes necessary in the future and I'm not feeling for it?
Avik Basu
84
I feel like Asus would be the right choice too. It's pretty much the same as the B450-F, which is supposedly a good performer. It's the only Bluetooth enabled board in my budget. And it looks good too. It does bother me that it'd mean a stranger touching my board but I guess it's a small sacrifice.
So the new setup is:-
Ryzen 5 3600
Asus ROG STRIX B450-E Gaming
Trident Z 16GB (2x8) 3200
Corsair 175R RGB
Good?
Avik Basu
84
Thanks. I'll hold off on ordering them for a day in case anyone else has other opinions. I have to go there personally to pick them up and have the BIOS updated and they are closed on Sundays so no point rushing it. But this is looking like the best option for me right now. Thanks again. Really appreciate all the help. I'll post an update once everything is settled.
Reactions: DMAN999
