The biggest problem in the Americas with this is unless you plan to game in your kitchen or bathroom you won't have an outlet that gets close to this. You can check your breaker panel, most of the outlets in your house are going to be 15 Amp outlets. 15 Amps x 120V = 1800 Watts. Usually but not always the outlets in your kitchen or bathroom will be 20Amp outlets, 20Amps x 120V = 2400 Watts. It's not likely you have larger outlets in your household (there are larger connections but the shape of the outlet is different from a standard 3 prong outlet). It doesn't mean they can't be correctly wired and created by a qualified electrician, but it's not likely to be cheap. This applies to the Americas, mostly the US and Canada, Europe and the rest of the world may be different. You do not want to change the breaker without having adequately gauged cable in your walls, this should only be done by a certified professional, if the cable is too thin you can set your house on fire. 2800W / 120V = 23.3334 Amps
