[SOLVED] 280mm fans won’t fit will 240mm fit
Jan 26, 2021
Hey I just got my nzxt 280mm and the ram appears to not let me 140mm fans each go in on top with the cooler if I got 240mm will it be any different maybe something is not compatible please look at my parts
maingear VYBE case
ASROCK z390 Taichi
32gb trident neo z ram
Will it fit with 240mm or do I need 1 fan liquid cooler?
This site: https://maingear.com/vybe/
I scrolled ALL the way to the bottom - scroll up a little, and found:
Liquid CoolingClosed Loop – Up to EPIC 240 SuperCooler
Regular Open Loop – APEX Soft Tubing Liquid Cooling for CPU and GPU with 240+360mm Radiators, High Airflow Fans and Distilled Deionized Non-Conductive Liquid
SUPERSTOCK Open Loop – APEX Hand Crafted Liquid Cooling with Crystal Hardline, premium chrome fittings, 240+360mm Radiators, High Airflow Fans, Distilled Deionized Non-Conductive Liquid
iu
That's a 240mm up...
hey what site are you talking about? The motherboard? Because it was blocking from the case to the ram and I couldn’t do 280mm are u for sure that 240 will work it’s to big up and down not the width the height of the fans. I need a response
iu
That's a 240mm up top.
iu
Another 240mm up top.
