2K/4K Monitor with Macbook Pro (Early 2015)
squashy1989
Hi Guys,
I have a PC(Hooked to old 23 inch monitors ) and recently I have shifted to Macbook pro and after using it at that high and crisp resolution I did not like it to extend to my old monitor as OS x is looking pixelated.
Decided to buy a 2k/4k monitor.
I have a question
Does 2K monitor good for watching movies/PS4 and browsing ?
Does it look pixelated ?
or 4k is the only solution to have a great display ?
Also 4k is really expensive and if 2k is is pixelated then is it good to wait for few months for the prices of 4k to drop ?
please help me out. Thanks in advance
2k shouldn't be pixelated unless you have a driver issue.
It a hard call. 4k is expensive. the ppi of a 4k 27" display is about 163. A 25" Dell 2k monitor has a ppi of 118.
If you get 4k i will only recommend an IPS panel. A decent 27" 4k IPS can be had about £450 in the UK. Problem is a 25" Ulttrasharp IPS panel 2k display from Dell (really nice monitor) retails for £260. 2k isn't as sharp as 4k, but it all depends how much you want to pay.
I do video and photo editing so i went with 4k, other wise a good 2k panel is acceptable. BTW do not get a 27"...
Just for browsing / watching movies / Coding stuff ...No editing
I do video and photo editing so i went with 4k, other wise a good 2k panel is acceptable. BTW do not get a 27" 2k panel as they are expensive at the moment (up to £370). At this price you can pick up a cheapish TN based 28" 4k monitor.
This link shows ppi. you can calulate the ppi of different resolutions and screen sizes.
https://www.sven.de/dpi/
Sorry i haven't really answered your question. But if you are on a budget a 25" 2k IPS panel may be your coice. It you are not bothered about colour accuracy and viewing angles, then a 28" 4k might be for you.
Thank you so much for the reply it was very useful.
I will now decide correctly.
