So I recently upgraded my second monitor to an LG 32UK50T. When I connected it initially it was through DP and it was detected but was getting no signal, while my primary was connected through HDMI and had signal. Tried all of my DP outputs on my GPU still no luck. Then I swapped the inputs from my monitors, primary on DP and this new secondary on HDMI. Now my secondary works but my primary is having the same issue; is detected by my PC but does not receive signal through DP. My previous monitor was connected through DP and had no issues what so ever. My GPU is a 1070, giving me 3 DP ports and 1 HDMI. I tried unistalling and rolling back my display adapter drivers, no luck again. Any suggestions? I will post other specs if needed.
