Hello, I have 2 PCs setup. Gaming PC with wifi connected to internet and Streaming PC (SPC) connected to the Gaming PC (GPC) with the cross cable (1Gb). From time to time I'm having trouble to get SPC to connect to the internet. In the beginning, I had all the LAN cards settings on auto. This sometimes worked and sometimes not. I found that if I bridge LAN and wifi cards on the GPC and then unbridge - SPC will connect to the internet (sic!). However, I need to have static IPs on both computers to enable VBAN. I set IP addresses on both LAN cards and was able to get the internet on the SPC but download speeds are down from 100Mbits to 2-4Mbits.
Can someone please help me sort this once for all?
Thank you very much,
Edit: someone recommended to buy switch and connect both pc to it. Set IPs to 10.0.0.1 /2 and 255.0.0.0 and leave default gateway blank. Done it but my SPC still doesn't connect to the internet 🙁 when I run troubleshooting it says that DHCP is switched off. When I switch on it just change IP to automatic (obviously). It connects to the internet but the download speed is throttled. I need static IP anyway for Vban to work... what I'm doing wrong?
