3 and 4 pin fan connectors
Ryzenhasrisen
144
My recently build pc has two four pin fan headers, one is taken up by the CPU fan. I have a fan lying around that takes a 3 pin connection. Can the 3 pin fit on the 4 pin header?
There is no 3pin PWM mode. It will run in voltage controlled mode. 3 pins, one is positive variable 5-12v voltage, 2nd ground, 3rd, RPM. 4 pin, one is 12v voltage, 2nd ground, third RPM, 4th, PWM signal.
Alright thanks. Worst case scenario I do have a spare four pin that I didn't see when I made this. However I'm not sure it will fit since I am using a mini itx case and it's a pretty thick fan. Is that worth trying?
