My PC has been acting up recently. Before (in my previous thread) I had issues with putting my PC to sleep (BSOD upon wake up) and this still happens.
So I've removed all my old HDD and SDD and replaced it with a new one, fresh install of Windows 10 - However I still can't successfully use sleep mode with my PC needing to suddenly restart or shut down.
Now I've been experiencing my PC being extremely slow at times and acting up - most recently my LED strips and the X570 Mobo LEDs were not on when booting up. So I launched Asus Aura Sync and upon attempting to launch, the PC ended up shutting down.
the only change I've done recently is install a new fan on the top of the case.
CPU temps at idle are around 45-50oC - which would be ok except I have a few other newly built PCs idling at around 30-40oC - and those PCs use AMD stock coolers while this PC is using a DEEPCOOL GAMMAXX 400
I need advice on what to do as clearly somethings up with a piece of hardware I have, all components except the GPU have been bought brand new 3months ago!
My build:
Motherboard: Asus TUF GAMING X570-PLUS
CPU: AMD Ryzen 5 3600
GPU: Nvidia GTX 1070 (This was bought used)
SSD: Kingston SSD A400 Solid State Drive (2.5 Inch SATA 3), 480 GB
RAM: Corsair Vengeance RGB PRO 16 GB (2 x 8 GB) DDR4 3200 MHz C16 (Recently added in, changing from Crucial Ballistix Sport LT BLS2K8G4D30AESBK 3000 MHz) - Also have enabled XMP (Or how ASUS call it D.C.O.P)
PSU: Corsair RM650
Any help/suggestions would be very much appreciated!
Thanks
-M
My build:
PSU: Corsair RM650
Thanks
-M
