[SOLVED] 3 pin argb onto 4 pin port adapter
rafovafo
62
I have a mobo with 2 4-pin argb headers and 4 3-pin argb fans. Is there an adapter or hub that can convert it other than the deepcool one since that one can only convert 1 fan so it doesnt make sense to buy.
Motherboard part number?
4 pin may be RGB 12 volt 3 pin ARGB 5 volt.
Look close at the MB description at the port. Do not mix ARGB and RGB.
https://duckduckgo.com/?q=motherboards+with+2+4pin+argb&t=h_&iar=images&iax=images&ia=images&iai=https://graphicscardhub.com/wp-content/uploads/2018/03/rgb-headers-motherboard.jpg
