Question 3 pin fan connector into a 4 pin MB socket
bradrcfii
41
Can I connect a 3 pin fan connector to a 4 pin motherboard socket that is labeled "fan"? I am planning using the 3 left pins leaving the right pin open?
Thanks,
Brad
You are approaching it correctly.
Be aware that you may have full-speed operation from a fan connector positioned in that way.
Check your MB manual and BIOS settings to see if those fan headers will support variable voltage speed control of the fans.
Thanks,
Brad
Yes. There's a plastic panel on the motherboards fan header that acts as a guide to direct you to the 3 pins you need to use...the connector on the fan wiring harness has guides on one side that will line up with the panel on the motherboard fan header.
