I recently purchased a skytech prebuilt Link to the Computer. This is the motherboard:Mobo. At first I noticed that the fans weren't adjustable in the bios, I contacted Skytech and they told me that that WPM connected in the fan control board was hard wired to the top of the case (which you can't open) where there's button to control fan speed but I don't notice any difference, in fact if I hold it down it changes the RBG lights for some reason even though there's a button for that next to it. Here's a pic of my fan control board: FCB. I told them my issue and they sent me another PWM cable that goes into that empty white slot on the top left that should run to a SYS_Fan Header. Here's the 3 pin PWM cable they sent me and my system fan headers:MOBO and PWM cable. The pwm cable doesn't fit in any of the headers. Is there any way to convert it into a 4 pin? Or is it that this mobo doesn't support this certain fan control board in order to manually adjust rpms of the fans? Or am I just completely missing something? Any help is appreciated, these fans are way too loud for my liking.
