[SOLVED] 3 results, but are they same thing?
technology is neat
BANNED
Mar 22, 2019
47
So I went on userbenchmark.com and searched rtx 2060. (Here's the link for the search if you are lazy) https://gpu.userbenchmark.com/Search?searchTerm=rtx 2060
So there are 3 results with one not mentioning "geforce" aka the top rated one. All they all the same? If you look at the first result you see that it says:
Model: NVIDIA GeForce RTX 2060 so how come they are different ratings?
The reason I want to know is because I am thinking of buying a PC on Amazon that mentions Geforce but this doesn't so idk... whatever.
This probably is so clear to some of you, but I don't know so here you go.
