3-way SLI Cooling
USAussie
I am looking at setting up a 3-way SLI using Nvidia 980s, I want to also be able to cool the cards outside the stock fans or to upgrade the cooling on the GPU with the space the SLI would provide. I would prefer to set up watercooling but I know that isn't a convienient option.
Well a custom water cooling loop would be ideal, as bulky after market air coolers would be too big.
So a small full length water block would make the cards thin enough to fit tubes inbetween them, unless you don't want to custom loop water cool.
Other than that most of the aftermarket cards (such as gigabyte) should be enough for 3 cards even if they are close together.
