Question 3060ti fan issues.
karinaq
13
My GPU, after the most recent round of nvidia updates, has decide to begin doing.. this
Fan 1 (which I recently replaced due to the motor failing) was fine for the past 2 months, but has began to flicker on and then off every few seconds. I've also had a set of GPU driver (i think) related bluescreens.
0x1000007e & then 0x0000001e 10 hours later on the 31st,
0x0000013a & another 0x0000013a about 14 hours apart on the 2nd,
and then on the 3rd, another 0x1000007e at 3am.
Not sure what's happening, any advice or suggestions would be appreciated!
Could have a look here. If you are keeping the card maybe some aftermarket fans might be in order?
View: https://youtu.be/-yQHAMz1v5g
Hi! perhaps, I plan on swapping the fans in my card tomorrow to see if the issue is the fan itself, or some other control thing. The fan that's having the issues currently is brand new, basically. My only issue with slotting in a case fan is that I don't have enough connectors on my motherboard for one, though i do have a spare.
Im also worried that if this is a software/driver thing, a new card won't fix it.
If it's still in warranty time to send it in again!!!!!!!!!
Look at the fan when it's reading 0 RPM if it's turning then probably a sensor problem.
The fan does actually start & stop in-line with the sensors, unfortunately.
Additionally, I'm pretty sure I voided the warranty by replacing the original fan. The little sticker on the screw got pretty mangled.
Sorry didn't see this
Should of replaced under warranty now it's on you depending on where you live different countries have different warrant rules.
mistakes happen, but, I agree!
oddly, today, the fan is back to normal, so it was definitely a software issue. Still not certain what, but, at least it doesn't seem to be a broken GPU!
And, now it's decided to go back down .. just at random. Didn't launch anything new, etc.
Have you tried MSI Afterburner to see if you can force it to run?
That's what I'm currently using for fan control, my thought is that it may be fighting another program, but I've no other programs installed that do fan control, unless Nvidia Control Panel itself is doing it.
After it went down like this, it went back up for another hour or so, and now it's back to starting and stopping every few moments.
