Question 3060TI using 60w on idle
veeljko23
338
I have a MSI RTX 3060TI Gaming X and it is using 57-60w on idle while gpu utilization is on 2-3% on desktop and i get that by using the performance overlay from nvidia, seems pretty odd. Im using it with a 12600kf and a 1080p@165hz and a 1280x1024@75hz monitors
Hey there,
That seems pretty high for idling. Mine idles at about 20-25 watts.
In NVCP under 3d settings, make sure the power management mode setting is set to normal.
What power plan are you running in windows? Put it to balanced mode and see if that helps.
Hey there,
Could be, im pretty sure i have it on max performance everywhere, i will check when i get home
