Hi all, sorry to be that guy but I'm lost and run out of ideas to try. I am very lucky to have a 3080ti FE and I decided to watercool it using the EK Special Edition waterblock. Now, this is my first ever gpu block (silly I know but only just brave enough to try it as wanted that small EK block so bad) .
All went well and I got a post, but temps are worse than when was air cooled (40c idle and 70c in game when on water) which leads me to think I've done something wrong.
I have checked the flow which is good, fans are on 100% to be sure had cooling covered but still temps seem way to high. I don't want to take apart again yet without knowing what to try as I dont have anymore thermal pads at moment.
I used the spread method with thermal grease which was evenly covered I felt. I'm leaning towards that I did not tighten it down enough (tightened to point just started feeling resistance) but worried going to far and braking a very expensive and hard to get card.
For info, the loop is:
Res > 360mm EK Slim rad (front mounted with 3x Corsair QL120 fans as intake) > 3080ti EKWB > 3900x EK Velocity block > 360mm Corsair XR7 (54mm) rad (top mounted with 3x Corsair QL120 fans as exhuast) > return to res
Case is an Antec Torque
Please tell me someone knows what I have done wrong as gone from feeling so proud of myself for doing it to totally disappointed 😞
