L Liamponage Honorable Aug 15, 2013 57 0 10,630 Sep 11, 2013 #1 I have Windows vista 32 bit running and want to upgrade to windows 8 64 bit. Is that possible ?
Solution USAFRet Sep 11, 2013 32bit to 64bit is a full reinstall. There is no 'upgrade'. And run the Upgrade assistant. It will tell you your options. http://windows.microsoft.com/en-us/windows-8/upgrade-to-windows-8
USAFRet Titan Moderator Mar 16, 2013 179,710 22,200 184,590 Sep 11, 2013 Solution #2 32bit to 64bit is a full reinstall. There is no 'upgrade'. And run the Upgrade assistant. It will tell you your options. http://windows.microsoft.com/en-us/windows-8/upgrade-to-windows-8 Upvote 0 Downvote Solution
