[SOLVED] 3200mhz ram problem, keep crushing
Mar 10, 2021
21
Hi there.., I’m 4 day’s struggle whit my ram memory and my Windows startup, i have Ryzen 7 3700x, RTX 3070, Asus B450-F Gaming and 4x8gb of 3200mhz Crossair RGB Pro ram and the thing is my pc keep crashing whit blue screen of death when I switch to DCOP, its working on 1.35v i found it stable on 3000mhz ( manual ) but i cant understand why i cant get 100% and what is the issue.
I update my bios to latest version and i didn’t overclock anything on my pc :/
thats a 2x8 kit, not 4x8
d.o.c.p. (xmp) profile is tunned for single ram set, theres a reason why they sell quad stick set
which means u have to set manual timings (if it will work)
4x8 has part number CMW32GX4M4C3200C16, but that isnt compatible with ryzen
corsair has listhed just those sticks as ryzen compatible (4x8GB vengeance rgb pro)
CMW32GX4M4C3200C14 (3200MHz CL14 - 439,99$) or
CMW32GX4M4Z2933C16 (2933MHz CL16 - 179,99$) or
CMW32GX4M4A2666C16 (2666MHz CL16 - 234,99$)
or u can go with 2x 16GB sticks, they have better compatibility and for some odd reason faster stick is cheaper
CMW32GX4M2D3600C18 (3600MHz CL18 - 199,99$)
CMW32GX4M2C3200C16...
CMW32GX4M2C3200C16 (3200MHz CL16 - 221,99$)
Reactions: mOb69
Again me..
i was searching about this and what do you think should i run just dual ch 2x8gb and stay on 3200mhz whit 16gb, because im now running 4x8 on 3000mhz
