I've been having some game and browser crashes lately where I'll get errors either from a game, or from Opera GX saying something like it's ran out of memory. At the time I was running 16GB (8x2) of the Vengeance 3600 Mhz. Originally I realized XMP wasn't turned on so I went in there to see if enabling it potentially would assist me with this but it did not (I know it usually works the other way around). I ended up buying two more sticks since I can use them for browsing and music production anyways... but I'm still getting the errors. Before AND after the upgrade I had also gotten BSODs a handful of times.
I ran memtest86 overnight and it seems to have a lot of errors. I finally realized that I'm using a 650W gold PSU that according to a couple of online calculators may not be enough to run the two HDDs, two SSDs, my 3070, and Ryzen 3800XT. Not to mention a handful of USB peripherals / phone charger. My system actually seemed to have gotten a bit more stable after unplugging additional peripherals that weren't totally critical. I'm just curious if anyone experienced with memtest86 can tell me if this readout seems like something that could reasonably be caused by an insufficient PSU. I will probably grab a gold 850W Thermaltake while it's on sale.
Thanks in advance!!
Summary
System Information
Result summary
Bits in Error
Thanks in advance!!
FAIL |
Report Date | 2022-06-15 09:13:10 |
Generated by | MemTest86 V9.4 Free (64-bit) Visit MemTest86.com to Upgrade to Pro |
Result | FAIL |
EFI Specifications | 2.70 |
System | |
Manufacturer | Gigabyte Technology Co., Ltd. |
Product Name | B550 AORUS ELITE V2 |
Version | Default string |
Serial Number | Default string |
BIOS | |
Vendor | American Megatrends International, LLC. |
Version | F14 |
Release Date | 01/04/2022 |
Baseboard | |
CPU Type | AMD Ryzen 7 3800XT 8-Core |
CPU Clock | 3893 MHz [Turbo: 3893.1 MHz] |
# Logical Processors | 16 (8 enabled for testing) |
L1 Cache | 16 x 64K (216924 MB/s) |
L2 Cache | 16 x 512K (89577 MB/s) |
L3 Cache | 1 x 32768K (35449 MB/s) |
Memory | 32685M (20999 MB/s) |
Number of RAM SPDs detected | 4 |
SPD #0 | 8GB DDR4 XMP PC4-28700 |
Corsair / CMK16GX4M2D3600C18 | |
18-22-22-42 / 3596 MHz / 1.350V | |
SPD #1 | 8GB DDR4 XMP PC4-28700 |
SPD #2 | 8GB DDR4 XMP PC4-28700 |
SPD #3 | 8GB DDR4 XMP PC4-28700 |
Number of RAM slots | 4 |
Number of RAM modules | 4 |
DIMM Slot #0 | 8GB DDR4 PC4-28800 |
Unknown / CMK16GX4M2D3600C18 / 00000000 | |
3600 MHz | |
DIMM Slot #1 | 8GB DDR4 PC4-28800 |
3600 MHz | |
DIMM Slot #2 | 8GB DDR4 PC4-28800 |
3600 MHz | |
DIMM Slot #3 | 8GB DDR4 PC4-28800 |
3600 MHz |
Test Start Time | 2022-06-15 00:41:28 |
Elapsed Time | 6:23:28 |
Memory Range Tested | 0x0 - 840000000 (33792MB) |
CPU Selection Mode | Parallel (All CPUs) |
CPU Temperature Min/Max/Ave | 40C/54C/46C |
RAM Temperature Min/Max/Ave | -/-/- |
# Tests Passed | 43/48 (89%) |
Lowest Error Address | 0x1241BB4 (18MB) |
Highest Error Address | 0x830B7DB94 (33547MB) |
Bits in Error Mask | 0000000000000080 |
Bits in Error | 1 |
Max Contiguous Errors | 1 |
CPUs that detected memory errors | { 0, 2, 4, 6, 8, 10, 12, 14 } |
. | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | x | . | . | . | . | . | . | . |
63 | 0 |
Test | # Tests Passed | Errors |
Test 0 [Address test, walking ones, 1 CPU] | 4/4 (100%) | 0 |
Test 1 [Address test, own address, 1 CPU] | 4/4 (100%) | 0 |
Test 2 [Address test, own address] | 4/4 (100%) | 0 |
Test 3 [Moving inversions, ones & zeroes] | 4/4 (100%) | 0 |
Test 4 [Moving inversions, 8-bit pattern] | 4/4 (100%) | 0 |
Test 5 [Moving inversions, random pattern] | 4/4 (100%) | 0 |
Test 6 [Block move, 64-byte blocks] | 4/4 (100%) | 0 |
Test 7 [Moving inversions, 32-bit pattern] | 3/4 (75%) | 2 |
Test 8 [Random number sequence] | 0/4 (0%) | 164 |
Test 9 [Modulo 20, ones & zeros] | 4/4 (100%) | 0 |
Test 10 [Bit fade test, 2 patterns, 1 CPU] | 4/4 (100%) | 0 |
Test 13 [Hammer test] | 4/4 (100%) | 0 |
Last 10 Errors |
2022-06-15 05:51:11 - [Data Error] Test: 8, CPU: 6, Address: 830B7DB94, Expected: 2E358DE7, Actual: 2E358D67 |
2022-06-15 05:51:11 - [Data Error] Test: 8, CPU: 12, Address: 82719B394, Expected: C54E1818, Actual: C54E1898 |
2022-06-15 05:51:07 - [Data Error] Test: 8, CPU: 4, Address: 815DF3214, Expected: 00650398, Actual: 00650318 |
2022-06-15 05:51:03 - [Data Error] Test: 8, CPU: 14, Address: 7E2660C74, Expected: 02715E18, Actual: 02715E98 |
2022-06-15 05:50:56 - [Data Error] Test: 8, CPU: 0, Address: 7BD796934, Expected: F1B18D18, Actual: F1B18D98 |
2022-06-15 05:50:55 - [Data Error] Test: 8, CPU: 2, Address: 799F1A154, Expected: B8C94B18, Actual: B8C94B98 |
2022-06-15 05:50:50 - [Data Error] Test: 8, CPU: 8, Address: 76D17D9D4, Expected: 13888918, Actual: 13888998 |
2022-06-15 05:50:48 - [Data Error] Test: 8, CPU: 10, Address: 749478414, Expected: 8278C867, Actual: 8278C8E7 |
2022-06-15 05:50:48 - [Data Error] Test: 8, CPU: 6, Address: 751489414, Expected: B7531B98, Actual: B7531B18 |
2022-06-15 05:50:34 - [Data Error] Test: 8, CPU: 14, Address: 6E0DFE754, Expected: B3C43BE7, Actual: B3C43B67 |
