[SOLVED] 3900x Temperature monitoring issues
helper800
697
54
19,140
29
I recently built my new PC based on the 3900x and have been having issues finding software that monitors per core temperature. I am not aware if that is even possible at this point as I have tried practically every program to do so. I am currently looking at Core Temp and it shows all the core at the same exact temperature, and I am assuming that is the average temperature across all cores. Am I missing something? Specs in CPU-Z link. PSU: Seasonic Prime Titanium 850W.
Reactions: valeman2012
CosmicDance
Proper
Jun 11, 2019
190
40
120
6
I use HWinfo64 which monitors absolutely every possible parameter and sensor of the PC.
It just indicates one general temperature of the CPU on its display.
Andy
helper800
697
54
19,140
29
AMD doesn't have per core sensors in the CPU. Hence why you only have one temperature for the die(s).
That is what I suspected although I was not sure because of the new chipset/bios/architecture of my system. My previous build was a 3570k which had this feature so I expected it to be the same with the 3900x. Thanks for the clarification.
