Just built new PC with Specs listed below:
CPU: Ryzen 3900x
Mobo: Asrock X570 Taichi
RAM: XPG D60 DDR4 3600mhz (reads as samsung die)
PSU: Tried OCZ GSX700 and Corsair RM 850x
GPU: GTX 1060 6GB and RTX 2080ti
Ive tried multiple attempts to get the RAM at rated speed of 3600MHZ using the XMP profile and it just loops until it resets. Currently its running 1333mhz so 2666. I have the 3900x running at stock with no adjustments made to it in the BIOS. The x570 was just updated top the new BIOS from 1.6 (new BIOS is 2.1 I believe). Both BIOS versions wont allow RAM to post at rated speeds but most concerning to me is the recent hard freezes that I have been having ever since putting in the 2080ti. I thought it was due to the PSU so I went and got a new one today and stuck the RM 850x in, same thing. I was playing a while on division 2, alt tabbed out and it froze after a few seconds.
so of my 2 problems with the RAM not reading the right speeds and the freezing Im starting to lean towards my mobo needing an RMA.
What I have tried for the RAM:
booting ram in slot A1+A2 (worked)
Booting ram in slot A1+B1 (worked)
Booting ram in slot A2+B2 (worked)
Booting with 1 stick of ram in each slot which worked about 80% of the time with multiple reboots before hitting windows.
Booting into XMP (didnt work)
Manually setting speed of 3600mhz (didnt work)
Ran Memtest86+ and it passed 4 passes with 0 errors
What I have tried for the freezing:
Installing new PSU (older 700 watt to brand new 850 watt)...still got freezing after leaving a game
reinstalling Nvidia graphics drivers (didnt work)
My CPU temps are never above 68, my 2080ti stays around 70 which I know is hot but its a blower design (I didnt buy it). The 1060 didnt seem to cause freezing in my runs with that installed. It also seems to freeze right when I leave a game which recently has been Division 2 and I have really only noticed with I alt tab out.
Realllllyyy looking for some other input because I'm getting a little flustered here.
CPU: Ryzen 3900x
