Hi, I have unused 2 years old 1stPlayer BLACK.SIR 450w power supply and recently, I'm quite active on making 3d stuff, so I thought I would use that power supply to build a dedicated renderer and make a render farm like environment with my other 2 pcs. but I wonder if I should use a GPU or not for the build, since the PSU only have a 6pin PCI power cable and I read somewhere that the most powerful GPU with 6pin PCI power socket is GTX 1060 which I don't think it is worth. My budget also limited to $700-$800.
So what do you think, should I put a GPU (GTX 1060) and if so, what is the optimum CPU combination for it? or should I go all-in with CPU with ryzen7 5800x or i7 12700
