I agree. But without knowing voltage and the stress test program we can only guess what is "good". Even delid I haven't seen below 65-70c under prime95 load.
https://gyazo.com/3699eae276324baf5f4f4353a6a4ffb4 tested with prime 95 for 5 minutes I can show voltage as well if you want or show a gif of it running this is after I reset my OC settings. Hwinfo said the same no failures. 56 was max temp that it went to.
5minutes is not long enough. 1 hour minimal to find the temps. 5 minutes and the Prime95 is still think about starting its full load. Anything less than 20minutes is pointless.
My bad misread your reply I'll start it again and post some pictures that was my fault I read your reply and just went to do it because I thought I saw did you run it for 5 minutes
