Hello guys,
I'm having trouble with Windows 8.1 and (possibly) my RAM. Everytime I format the computer, it runs smoothly for a few days, but after that, I start getting random reboots (without any warning). After shutting down, the mobo beeps 4 times (short beeps) and it tries to restart (it usually succeeds on the 2nd attempt). I've read the 4 short beeps could be happening because of some RAM problem, but i'm not sure if it's a configuration problem in the BIOS or really a bad ram module...
These are my specs:
Intel Core i5 3570K
Asrock Z77 Extreme4
Gigabyte GeForce GTX 660 OC 2Gb
8GB (4x2) G.Skill Ripjaws X DDR3 1600 (F3-12800CLD8D-8GBXM)
PSU: Corsair CX600M
Also, I have to say that after (randomly) removing one of my ram modules (actually, the most accesible module) the computer starts and runs (so far) without any issue. I find it hard to believe that i happened to remove the faulty module (chances are 1/2) so I'm more inclined to think that it's all have more to do with a configuration problem in the BIOS (?)
As one last piece of info, all these problems started happening after happily using W 8.1 for like 2 months, I woke up one day and my computer started acting up like this...
What do you guys suggest? Should i enter the RAM clocks manually in BIOS? Try to update BIOS? (I think asrock hasn't updated it in like forever) or run a Memtest?
Cheers ;D
These are my specs:
Intel Core i5 3570K
Asrock Z77 Extreme4
PSU: Corsair CX600M
Cheers ;D
