M mrtopkek Prominent Apr 20, 2019 24 0 510 May 12, 2019 #1 hi, i have an intel i5-7500 cpu and i want to know if a 4pin 12v connector on the motherboard(instead of an 8 pin) can cause performance issues. thanks. the motherboard: asus prime b250m-k
COLGeek Cybernaut Moderator Apr 6, 2009 54,225 3,430 179,340 May 12, 2019 #2 No, it should be fine. No worries. Upvote 0 Downvote
jankerson Judicious BANNED Sep 10, 2006 7,885 140 35,640 May 12, 2019 #3 No, the Prime is a low end model, basic. With your CPU it won't matter. Upvote 0 Downvote
M mrtopkek Prominent Apr 20, 2019 24 0 510 May 12, 2019 #4 COLGeek said: No, it should be fine. No worries. Click to expand... jankerson said: No, the Prime is a low end model, basic. With your CPU it won't matter. Click to expand... thanks Upvote 0 Downvote
