[SOLVED] 4 pin connector into a 3 pin connector?
Tobacha
21
Hi Guys and gals. I was wondering, my Deep Cool fans and CPU cooler cam with a 4 pin RGB connector but my fans are 5v so was wondering. I am thinking that I would need to plug or need a 3 pin aRGB header connector to plug into the fans because they are 5v? Or can I just plug the 4pin connector into the 3pin 5v connector on motherboard. I got an MPG x570 Gamer Plus. It has two headers a 12V and a 5V for RGB's. Thanks'. Hope this made sense.
Several misunderstandings there leading to errors.
First, note that "RGB Fans" really each are TWO devices in one unit - a fan MOTOR and some LIGHTS in the frame - and they each have their own separate cables that go to different mobo headers.
Next, note that there are TWO different designs of lights now dominant. The plain RGB system uses a 4-pin connector that supplies a common +12 VDC power supply line and three separate Ground lines - one for each of the three LED colours in the lights strip or fan frame. The Controller on the mobo manipulates the three Ground lines to generate thousands of possible colours that change over time, but at any one moment the entire light strip is ONE colour. The more complex Addressable RGB (ADDR...
my prepaid center
If you want to use the PWM function then the 4 Pin fan must be connected to a 4 Pin header on the motherboard. If you connect the 4 Pin fan connector to a 3 Pin header, then the fan will run at maximum RPM.
Ignore that post above - your problem is NOT the 4-pin fan motor connector, it is the DIFFERENT 4-pin RGB lighting connector. NO, you cannot plug the 4-pin plain RGB connector for those lights into a mobo 3-pin ARGB header. See your mono manual p.39. The mobo has two 4-pin plain RGB headers called JRGB1 and 2, at top and bottom edges. Use one of those. Do NOT use the JRAINBOW headers (p.40). If you do not have enough headers for all your lighting cables, get a 4-pin plain RGB SPLITTER cable like this to connect several units to one header.
https://www.amazon.com/Splitter-Con...616509795&sprefix=RGB+Splitter,aps,184&sr=8-5
That is a 2-pack of Splitters with 4 output arms each. NOTE that all the connectors on them are famale, and they come with gender-changer adapters to convert the output arms to males. You need those to be male, so do not buy a Splitter without them.
Reactions: Tobacha
Okay thank you so much for your reply!! I have been trying to get information on what do do and how to connect my fans 6 total without having the same thing happen that happened last time. I was fishing around for information with this post. Basically here's my specs first off:
CPU: AMD Ryzen 5 2600x
Ram: HyperX 8GBx4 3000mhz
GC: EVGA RTX 2060 8GB
PSU: Corsair CX 750M
Case: Rosewill Mid -Tower Gaming PC Case
MB: MSI X570 Gaming Plus
Captain 240RGB v2 liquid CPU cooler with two RGB fans including CPU RGB cooling fan.
3RGB RF120 fans Deep Cool added to front of case.
I at first daisy chained all the RGB lighting connections together and connected the fans well 4 of them to a fan hub and the rest to the mobo.
Then I connected all the RGB lighting connections that were daisy chained together to the one 4pin connector and plugged that into the 12V header on the mobo and the lights all of them came on for about 3 seconds then my comp went dead. After that my Dram light on the EZ Debug indicator on the mobo was red. So I called customer support for MSI. They walked me through unplugging everything and testing all the ram sticks one by one and the computer booted...All the ram was fine. So since then I haven't tried anything. I've posted in 3 forums about this to no avail. I am unsure what happened besides I overloaded the ram somehow by maybe attempting to plug in to many RGB fans into the 12V header? Otherwise I am looking for a solution to this. So this is why I was wondering if maybe I needed to find a different plug or I possibly could just use the 4pin header plug into the 3 pin Jrainbow for less voltage. But now I understand that's not the case. If you have any solutions about this PLEASE let me know!! Thank you in advance!
Link us to exactly what you bought please.
3RGB RF120 fans added to front of case. (these both came with a 4 pin rgb header connector.) Please see my reply below for my problem I am looking for a solution for. Thanks!
Next, note that there are TWO different designs of lights now dominant. The plain RGB system uses a 4-pin connector that supplies a common +12 VDC power supply line and three separate Ground lines - one for each of the three LED colours in the lights strip or fan frame. The Controller on the mobo manipulates the three Ground lines to generate thousands of possible colours that change over time, but at any one moment the entire light strip is ONE colour. The more complex Addressable RGB (ADDR RGB, ARGB, or Digital RGB) system, uses a 3-pin connector (looks like the 4-pin one, but with one pin missing (hole blocked off)) that supplies common +5 VDC and Ground lines plus a digital Control Line. Along the strip all LED's are organized into NODES, with each node containing one Control Chip and one :ED each of the three basic colours. All of the Control Chips listen to the Control Line which carries data packets of instructions with unique addresses, and each chip responds only to packets for its address, and does what it is told for its three LED's only. Thus at any one moment, every Node along the strip can be a different colour, and more complex displays are possible including rainbows, stationary or moving. Because of the major differences in voltage supply and display control methods, these two systems are INcompatible and can NOT be mixed in one circuit. You MUST plug 4-pin plain RGB lighting units (including fans with 4-pin lighting cables) into ONLY a mobo 4-pin plain RGB header. (MSI calls these JRGB.) Similarly, 3-pin lighting cables can ONLY be plugged into mobo 3-pin ARGB headers. (MSI calls these JRAINBOW.) OP, your mobo has two of EACH of these two header types.
From your list of components, the Gamerstorm Deepcool Captain 240PRO V2 CPU cooling system comes with ARGB lighting types in its two rad fans, and similar lighting in the pump unit. (PLEASE CHECK: you quoted Captain 240RGB v2, but I could not find that model. Do you really have the ...240PRO V2 model as I suspect, with ARGB lights?) Assuming that is correct, the lighting cables from all three components can ONLY be connected to a JRAINBOW header of your mobo. And then you say you have added to the front of your case three "RGB RF120" fans by Deepcool. ALL of the model RF120 fans from Deepcool say they are for the OTHER lighting system - the plain RGB with FOUR-pin lighting cables. These can ONLY be connected to the JRGB header of your mobo. You can NOT connect all those lighting units together in one circuit!!
I'm also a bit confused. It is not clear which case you have - there are many Rosewill cases for mid-tower sizes. And some (maybe all??) of them come with pre-installed front fans. So, did your case have fans? Did you remove them and replace then with the three Deepcool RF120's? If you did, where are they now. This is all part of the fan count. You say you have six to connect. Then you list three RF120's in the front, two on the rad for the CPU cooling system and the last one????
The rad fans normally should not be included in the count of CASE ventilation fans because they are to be connected to different mobo fan headers. The Captain 240PRO V2 system should be connected this way. Plug the PUMP unit's 3-hole female connector into the mobo PUMP_FAN1 header. Then using the fan MOTOR Splitter box supplied with that system, connect both of the rad fans to the CPU_FAN1 header. Ensure that both of those headers are configured in BIOS Setup (see mobo manual p. 62) to use PWM Mode (upper left of the graph pane). With these settings, the pump will run full speed all the time and its speed signal will be monitored for possible pump failure. The two rad fans will have their speeds controlled automatically according to the temperature measured inside the CPU chip by a sensor. That system also comes with an ARGB LIGHTING Splitter. You connect the two rad fans to ports 1 and 2 of that, and the PUMP lighting cable to an end port. The cable from this Splitter goes to one of your JRAINBOW headers on the mobo so MSI Mystic Light can power and control those ARGB lights.
CASE Ventilation fans - the three Deepcool RF120's that I believe have FOUR-hole (female) lighting cable connectors and separate FOUR-hole (female) FAN MOTOR cable connectors - should be connected using a fan motor Splitter to one of the four SYS_FAN headers on the mobo (p. 34). IF you have other case fans, use another Splitter to connect them to another SYS_FAN header. In BIOS Setup (p. 62 again) go to the screens for each of those SYS_FAN headers you have used. For each, start below the graph to the right, and click on the "Set All Default". Then go to upper left. For any header with 4-pin fans, set it to PWM; if you have 3-pin fans connected to a header, set that one to DC. Then just below that for the Temperature Source, set this to motherboard, not CPU. When all fan headers have been configured, use Esc back to the Main Menu, then use F10 to call up a screen and choose the Save Changes and Exit option.
Assuming that the case fans contain FOUR-pin plain RGB ligthing units, use a 4-pin RGB Splitter cable to connect them to one of the mobo JRGB headers. Again, MSI Mystic Light will power and control them.
I suspect the small disaster you had first time around is becasue you connected ALL lighting cables together to the 4-pin JRGB header, and that is WRONG for the 3-pin lighting units. I am not sure how you could do that - it is supposed to be impossible to plug 3-pin female lighting connectors into 4-pin male outputs. I hope you did not try to connect the lighting cables to mobo FAN MOTOR headers. Anyway, you have the fan motors working now. If you connect the LIGHTS as above, they should work (unless your first connections damaged some of the 3-pin systems).
Reactions: Tobacha
Here's the link to my CPU cooler. https://www.amazon.com/gp/product/B07QPNP4VP/ref=ppx_yo_dt_b_asin_title_o07_s01?ie=UTF8&psc=1
its a 12V connection. Thank you so much for replying to my thread here. What I ended up doing was using the RGB splitter I bought from the above reply and hooking up the CPU RGB header to one of the splitters off the JRGB Mobo header and the other three fans (which I replaced the LED fans that came with the case with) and hooked that into another of the Mobo splitters. That solved the problem. All the lights came on and it didn't overload the RAM which is what I am thinking might have happened. I pieced this all together through going to Geek squad and asking the guy there about how to go about fixing my RGB lighting and told him my problem. He mentioned that my mobo might not have enough RGB headers. Then the other response I got saying to get the splitters made sense to me because the CPU cooler came with its own 12V header and so did the fans.
Now the Bios stuff looks really helpful. Thank you again!
You are welcome. I really think the problems you had earlier actually had nothing to do with your RAM. I have found at times that the error messages (or lights) one gets tell you the wrong things about the cause of the problem. The problem may have been overloading of a single mobo JRGB header, I'm not sure. But now you have fixed it, so hurray!
Thanks for the detail on your CPU cooler. You have an older version that uses the plain RGB fans, rather than the most recent one using ADDR RGB. I was a bit suspicious of that, and that is why I asked you to confirm. I had looked on the Deepcool website in their "Discontinued" listing but it never showed me that version. With that correction to my understanding, it now makes total sense!
Reactions: Tobacha
