4770k @ 5 GHz with 1.048 Vcore? Need help stabalizing
i7hero
27
Hello, I've been experimenting with overclocking and am still fairly new to it. I've watched many guides and the highest stability I've reached so far without tweaking is 4.8 GHz @ .9 Vcore or so. How could I tweak my 4770k to be stable @ 5 GHz? I'd love a professional guide where I can try to achieve this goal. All assistance is welcome, btw, cooling is not an issue.
You've started several threads concerning overclocking your 4770K, the first of which I think was i7-4770k stable @ 4.8 GHz - http://www.tomshardware.com/answers/id-2190700/4770k-st....
At 5.0Ghz, that voltage is only possible during idle or very light loads. Use CPU-Z and Core Temp while running Prime95 Small FFT's to properly test your CPU at 100% workload.
It's all explained in the following Sticky: Intel Temperature Guide - http://www.tomshardware.com/forum/id-1808604/intel-temperature-guide.html
Also, here are some Haswell overclocking Guides:
How to Overclock an Intel 4770K Guide - http://www.overclockersclub.com/guides/overclock_intel_...
3 Step Guide to Overclock Your i7 / i5 Haswell Platform -...
3 Step Guide to Overclock Your i7 / i5 Haswell Platform - http://www.overclockers.com/3step-guide-to-overclock-in...
Intel Haswell Overclocking Clubhouse - http://www.techpowerup.com/forums/threads/intel-haswell...
Hope this helps,
CT :sol:
