Question 4g decoding does not turn on
Update your post to include full system hardware specs and OS information.
Also please be more specific about the question(s) you are asking regarding the posted window.
I believe the requirement/objective is to enable Resizable BAR - correct?
I understand wanting to improve performance.
However what is the current level of performance and what change in performance is expected?
What will be used to measure the performance and subsequent performance changes?
try looking in your nvidia control panel see if there is anything at driver level that allows you to enable or disable the feature I know in amd it's called SAM and can be toggled on or off at driver level, also make sure your bios has secure boot set to enable and is active (noticed CSM UEFI mode is disabled in your post)
basicly for me I had issues with SAM with it enabled performance was worse in every game and I mean massively worse until I changed bios settings to CSM UEFI mode to disabled, I rebooted the motherboard and went back into BIOS settings, went in to secure boot section of the BIOS selected custom which allowed me to factory resest secureboot, the motherboard rebooted and I went back into bios, in the secure boot section, loaded factory default settings then changed the secure boot setting back from custom to standard, which the motherbard reboots its self, again going back in the bios in the secure boot section I checked to make sure it was set to enabled and said active.
I then formated my main drive and reinstalled windows and things seem to work as they should.
But was it worth the effort? not really games seem to run the same or if there is any difference i'm buggered if i can notice it.
Обновите свой пост, включив в него полные характеристики системного оборудования и информацию об ОС.
Также, пожалуйста, будьте более конкретны в заявлениях, которые вы задаете относительно опубликованного окна.
Я считаю, что требование/цель состоит в том, чтобы включить панель изменяемого размера, верно?
Я понимаю, что хочу улучшить производительность.
Однако каков нынешний уровень производительности и какие изменения в производительности ожидаются?
Что будет использоваться для измерения производительности и уменьшения изменений производительности?
HexaCore AMD Ryzen 5 5500, 4250 МГц (42,5 x 100)
PCI Express 3.0 x8: nVIDIA GeForce RTX 4060 COLORFUL,
Gigabyte A520M DS3H V2 (1 PCI-E x1, 1 PCI-E x16, 1 M.2, 4 DDR4 DIMM, Audio, Video, Gigabit LAN) BIOS F3d(Latest)
Chipset: AMD A520, AMD K19.5 FCH, AMD K19.5 IMC
DDR4 16 GB 3200MHZ(XMP)
SSD SATA AHCI 512 GB
Windows 10 Pro 22H2
At the moment, the performance level corresponds to PC components, I saw in tests that a resizable bar can increase FPS by 10-15%, why not? I'll look at the FPS in the game
попробуйте заглянуть в панель управления nvidia и посмотреть, есть ли что-нибудь на уровне драйвера, которое позволяет вам включать или отключать функцию, которую я знаю в amd, она называется SAM и может быть включена или выключена на уровне драйвера, а также убедитесь, что в вашем биосе есть безопасная загрузка установлен на включение и активен (в вашем сообщении заметил, что режим CSM UEFI отключен)
в основном у меня были проблемы с SAM, когда он включен. Производительность была хуже в каждой игре, и я имею в виду значительно хуже, пока я не изменил настройки BIOS с режима CSM UEFI на отключенный, я перезагрузил материнскую плату и вернулся к настройкам BIOS, вошел в безопасную загрузку раздел BIOS, выбранный пользователем, который позволил мне восстановить заводские настройки безопасной загрузки, материнская плата перезагрузилась, и я вернулся в BIOS, в разделе безопасной загрузки загрузил заводские настройки по умолчанию, затем изменил настройку безопасной загрузки обратно с пользовательского на стандартный, после чего материнская плата перезагружается. сам по себе, снова вернувшись в биос в раздел безопасной загрузки, я проверил, включен ли он, и сказал, что активен.
Затем я отформатировал свой основной диск и переустановил Windows, и все работает как надо.
Но стоило ли оно затраченных усилий? на самом деле игры не работают одинаково, или, если есть какая-то разница, я в недоумении, если смогу это заметить.
Setting Security Boot to Enable did not help, there is nothing like that in the drivers either
To be honest, to me it seems SAM is more one of those features that is simply a feature, it does what it's supposed to do with the games it works with but the end user is more than likely not going to notice the up lift in real time.
It just another feature that makes the numbers bigger and because bigger is better in some cases it doen't always warrant the hype.
It's one of those features that more likely to niggle the end user into wondering/thinking are they missing out if they dont have it enabled. It probs mainly depend on the design of the hardware on how important resize bar is?
like intel gpu's apparently need Resize Bar or the hardware performance will take a big hit but not so much if any with AMD or Nvidia Hardware.
I could be wrong but thats what I make of it from what I have read.
