4K Help!!!!!! PLEASE
Jaydon382
Commendable
Jan 2, 2017
50
Ok so I have this new screen: https://www.newegg.com/Product/Product.aspx?Item=N82E16824009893
and I read somewhere that for '"3840x2160 60Hz" or "4K", I will need two dual-link DVI outputs and your monitor Has to accept two inputs' so I have two GPU's in Sli each has one DVI Port.
So do I have to have two Dvi port's Total like I can use One Dvi on Gpu1 And the second Dvi in Gpu2, or do I need Both Dvi outputs on The primary Gpu or Gpu1?
And also another quick question What does "Dual-Link" Mean?
Thank you!!
EDIT: So HAHA just realized my screen doesn't have DVI, It has 1x Display Port Can I still get '"3840x2160 60Hz" or "4K" using DVI let alone only 1???
Specs:
Cpu: Intel Core i7-6800K 3.4GHz 6-Core
Cpu cooler: Corsair H100i 77.0
Motherboard: MSI X99A GAMING PRO CARBON ATX LGA2011-3
Ram: G.Skill Ripjaws V Series 16GB (4 x 4GB) DDR4-3466
Ssd: Kingston SSDNow V300 Series 120GB 2.5"
Hdd: Hitachi Ultrastar 7K3000 3TB 3.5" 7200RPM
Gpu: Asus GeForce GTX 1080 8GB STRIX "X2"
Psu: EVGA 750W 80+ Gold Certified Fully-Modular ATX
Case: NZXT Phantom ATX full tower
Os: windows 7
Not sure the point of this question? You just need a DisplayPort cable from one of your 1080's to your monitor. As long as they are SLi'd, that all you need to do.
