Question 4k ycbcr 4:2:0 30bit 59hz HDR10 vs 4k ycbcr 4:2:2 24bit 59hz HDR10 vs 4k RGB 30bit 23 hz HDR10
john3569
29
Which one of these setting would be best for watchnig 4k UHD Blu Ray movies on my Xbox One S?
TV specs: https://www.displayspecifications.com/en/model/fc3013d8
TV manual: http://www.specsserver.com/CACHE/mefnbkuubcpt.pdf
Receiver specs: https://intl.pioneer-audiovisual.com/products/av_receiver/vsx-534/specification.php (scroll down to video features)
Another more specific thing for receiver: https://jp.pioneer-audiovisual.com/manual/vsx534/supple_534.pdf
I am playing these movies on my xbox one S,. I have been playing around with the video settings in the xbox's menu and after each modification of the settings a different status shows up when I press the status button on my receiver (it just tells you what the current input and output are being displayed at for both video and audio). Note that I am changing the settings then playing a 4k UHD blu ray prior to viewing the status (
By disabling "allow 24hz" and disabling "allow YCC 4:2:2" I got 4k ycbcr 4:2:0 30bit 59hz HDR10
By disabling "allow 24hz" and enabling "allow YCC 4:2:2" I got 4k ycbcr 4:2:2 24bit 59hz HDR10
By enabling "allow 24hz" and disabling "allow YCC 4:2:2" I got 4k RGB 30bit 23 hz HDR10
(enabling both of these setting results in the same status as the last)
I am pretty sure that most movies are 24p so am I correct in assuming that 23hz would be the best option? The only thing is that I've also heard that most blu rays and movies are naturally ycbcr 4:2:0.
As you can see I can not get both working simultaneously, they seem to be mutually exclusive. (I can only get 23hz in RGB and can only get ycbcr 4:2:0 in 59 hz.
Any insight would be appreciated!
As they seem to be mutually exclusive on my tv, which would be the better setting for watching 4k HDR10 blu ray movies.
I have been led to believe that all blu rays are encoded in ycbcr 4:2:0 but also that most movies are filmed in 24p.
