Im considering getting into a multiple array but Im not sure if what I want to do is possible.
Obviously, RAID 5 is not for me since I am looking for performance. I plan on building a video editing workstation.
So heres what I would like to do;
I want to get 2 Raptors 150GB in RAID 0, which I will use for OS and rendering, If I need extra space for my renders, Ill consider adding a third disk to the arrays, 450GB should be enough for HD, as long as its one file at a time.
I then plan on having a backup HD which I will use to keep all the important stuff, so if my RAID 0 dies, it wont matter cause I will try and keep it as cleen as possible to help keep performance maxed out.
The trick is to get the Backup HDs into a seperate RAID 1 config. I would then buy two Caviars 500GB, or I could set up a RAID 5 with 3 Caviars 500GB, which if im not mistaken will give me 1TB and any drive can die before I loose the array, so its pretty decent fault tolerance. Since I will be doing mostly reads from the backup, then I dont mind the slow write performance compared to a RAID 1.
The thing about this is that I want two basically have two seperate arrays that dont do anything together, its one HD for a RAID 0 and seperate RAID 1 or 5 that acts alone.
From what I have read, you can add arrays, but they work together, I want to know if I can get two completely seperate arrays for two HDs, one that for OS in RAID 0, one for backup/storage in RAID 1 or 5.'
THANKS FOR THE HELP!!!!
