[SOLVED] 4x4gb 3000mhz, but individually run at 2133mhz
decoyfuture
37
So, my ram advertises 3000mhz, do they have to run at 3000mhz individually? Is that i wanted to put my ram to atleast 2933mhz. The problem, is that, even putting them at 2400mhz my pc keeps rebooting with no signal on my monitor until it detects that there is a problem and boots up to bios. Should i better be staying on 2133mhz on my modules? (Keep in mind that im still a newbie on this, and i havent tried to touch dram voltages and all that)
couple of questions:
Are you putting it at 3000mhz with xmp?
Are all 4 sticks from the same kit?
If not, are they atleast the same model and speed? are the timings the same?
and if the answer for all of the above is yes, your cpu just has a weak sauce memory controller.
Try popping 2 sticks out and see if you can get to 3000mhz that way.
