I think the most I can afford is a 5060ti atm. I'm wondering the best system to build around it. I'm upgrading from a phenom 1100T system with 32gb DDR3 and a 10603gb card. I'm assuming the 10603gb is not worth keeping.
https://pcpartpicker.com/user/Aital/saved/#view=hc93Hx <-should be public
CPU: I was looking at a 9800x3d, but I'm assuming it's too powerful and a waste. I saw a 9600x at only 200 dollars for a good looking deal. Or is a 9700x or 9900x better? (I think I'm going with the 9600x.)
Memory: 2x16gb Vengance ram at 6000mhz latency 10. Cheapest I could find.
GPU: 5060 TI Zotac 16gb gaming amp
HDD: Samsung 990 pro 2tb for cheap storage, or 9100 pro 2tb. Which one is better? (going with 9100pro)
Motherboard: Looking at the Gigabyte Auros elite AX. Do I need V2 version? it says the CPU might not work right with the wrong bios.
CPU cooler: Thermalright Peerless Assassin 120 SE ARGB. LIterally for the RGB so I can see inside the case. My old case has dead RGB lights in the fans now.
And I have a very ancient 650w PSU. Should that suffice? It's an ancient corsair. Corsair TX650W power supply. It was release in 2008.
silentpcreview.com
Corsair TX650W ATX12V power supply
The TX650W is one of the middle models in Corsair’s growing line of power supplies, which now stretches from 450W all the way to 1000W, and includes modular cable versions as well. Previous reviewed Corsairs have all made it to the top of our short list of super-quiet power supplies. Does the...
