6-Pin GPU power connector required?
16mhinman
I am doing my first build with a MSI z77 MPower motherboard, and I noticed there is a 6-pin video card power connected on the board that my power supply did not provide a cable for. I am using a GTX 660 Superclocked and was wondering if I need to use the connector if I'm supplying the power directly. Thanks in advance for any help.
Google?
Http://forum-en.msi.com/index.php?topic=105930.0
"I asked MSI tech support if I need to connect to the JPWR3 if my vid card had a PCI-E 6 pin power connection.
Tech support reply:
If the PCI-E video card has it's own power connection on the card then the JPWR3 connection is not needed. This plug in only needed when the PCI-E video card does not have it's own power connection which is to ensure stability for the PCI-E video card without the external power connection."
