I Ineverhadausername Jun 25, 2019 8 0 10 Jun 30, 2019 #1 Probably a really stupid question with an obvious answer but I can connect 6-Pin GPU to PSU with 6+2-Pin PCI-E socket, right? My PSU doesn't have a normal 6-Pin one.
RememberThe5th Illustrious Jul 30, 2014 6,995 170 41,140 Jun 30, 2019 #2 You can disconnect that extra 2pin (since they are just ground wires). It indicates with 6+2. Upvote 0 Downvote
helpstar Titan Dec 25, 2012 14,223 945 83,840 Jun 30, 2019 #3 Yes, you can just plug in 6 of the 8pins provided by your power supply. Usually the 2 extra pins can be unclipped/seperated from the plug: http://www.playtool.com/pages/psuconnectors/pcie6plus2.jpg Upvote 0 Downvote
