64-bit or 32-bit?
At this point there is no reason not to get a 64-bit OS which allows you to access more than 4GB of RAM.
Regarding the above comment. Building you own PC is not for everyone especially if you do not have the time or the inclination to do it yourself. Purchasing a prebuilt PC means you also get tech support and limited warranty from a single vendor rather than the vendors of each individual component.
So 64 bit?
Yes. I'd much rather get a prebuilt because I feel I'll break it if I try myself aha
64 for sure, but if you're unsure you can use the same licence to install both.
The only reason to use a 32 bit version of Windows is if you have some legacy 16 bit software that absolutely cannot be emulated or run through a virtual machine.
