Do you mean how will it perform? Not much different to a 32-bit install. It'll likely use a bit more memory with 32-bit apps, but if you have 64-bit versions it should use less.
I run 4GB(2x2GB) in dual channel of course in my lappy..
I think that I have only a 4GB limit but even if I could run 8GB, I wouldn't have any need for that in a lappy..
is it possible to have a 4GB(one sim)+1GB(second sim) RAM config in a laptop ?
As long as the hardware is happy with how things are setup Windows 7 won't care how the memory is configured.
Have you checked your manual to see if that 4+1 combo is allowed?
if you have the RAM then try it and see...
If you unit has two RAM slots and then manual or web-site says it can handle up to 8GB then it can run the 5GB.
just 5GB is such and odd number and the way you have it 4+1 is just plain odd too..
the reason i am sticking to the figure of 4+1 is since that is the least figure i should have to run a 64 bit OS, least cost wise too.
no...
4GB(2x2GB) matching kit is all you need especially for starters...
the if need more (I doubt) then get an 8GB(2x4GB) kit (matching set).
that's how to do it the best way..
are both sticks the same as in specs or better even the exact same maker and specs.?
speaking of the 4+1 you posted about.
no...
ya same ddr3 and frequency , i need to know if 64 bit Win 7 will recognize the 4+1 combo and how much system memory will Win 7 show or report ?
