[SOLVED] 650 w psu enough to run this build at max? Not going to upgrade anything anytime soon so no need for future proofing.
Feb 25, 2019
17
Motherboard: MSI B450M PRO-VDH Gaming Motherbard
CPU: AMD Ryzen 5 YD1600BBAEBOX 3.2GHZ 6 Core AM4 Boxed Processor
RAM: Corsair Vengeance LPX 16GB 2x8GB DDR4 DRAM 3000MHz PC4-24000 C15 Memory Kit
GPU: Sapphire 11265-05-20G Radeon Pulse RX 580 8GB GDDR5 Dual HDMI/DVI-D/Dual DP OC with Backplate (UEFI) PCI-E Graphics Card
SDD: Samsung 970 Evo Series - 250GB PCIE NVME - M.2 Internal Solid State Drive (MZ-V7E250BW)
HDD: 2 X Western Digital WD10EZEX 1TB Internal Hard Drive for Desktop (Blue)
PSU: Corsair CP-9020098-UK VS Series VS650 650 Watt Power Supply Unit
CASE: Circle Gaming Phoenix ATX Tower Case with Transparent Side Panel Cases
COOLER: CHIPTRONEX Diffuser X500 RGB CPU Cooler with 5 Copper Heat Pipes(Black)
DVD writer, Bluetooth 4.0 WiFi pci card
The VS650 isn't a great quality PSU known for longevity etc....
If you already have it, it's not going to blow up or anything. But if you're considering buying &/or can return it for something else, I'd suggest you do so.
650W itself is more than sufficient for that setup, as would 450-550W range units...... but quality is what matters.
Given a UK serial/variant, I assume you're located in the UK?
From what I can find, the VS650 is ~47quid on Amazon.
https://www.amazon.co.uk/Corsair-VS...?ie=UTF8&qid=1551127568&sr=8-1&keywords=vs650
I'd be much more confident in a TX550M, but that'll push you up to ~60quid...
Barty1884
Retired Moderator
https://www.amazon.co.uk/Corsair-CP...ie=UTF8&qid=1551127583&sr=8-1&keywords=tx550M
Or the CX550 at ~55
https://www.amazon.co.uk/dp/B06X9BV5PR/ref=twister_B072QGL961?_encoding=UTF8&psc=1
For an RX580 + R5 1600 though, if your budget is 47quid max, the CX450 would do in a pinch
Sufficient for running your proposed setup at stock speeds.... Wouldn't push overclocks on it, personally.
The CX450 is also ~47
https://www.amazon.co.uk/Corsair-CP...TF8&qid=1551127600&sr=8-4&keywords=cx550&th=1
