[SOLVED] 650W is enough for RTX 2060 and Ryzen 7 3800x ????
Apr 29, 2021
4
I got Ryzen 7 3800x
and a 650W + Gold Corsair PSU
will be enough for an RTX 2060 or i need higher?
also have a MSI 32' Gaming monitor
MSI X570 MOBO
16Gb RAM
M.2 500Gb
Need Help
Thanx!
I m new to this is my first build and i got the PSU before everything thinking that will be enough i dont know what to do for future proof solution! give back this one as new or use it and risk it?
The CPU draws about 145 watts stressed with prime 95, the video cards depending on the model 160 to 180 watts, about 60 for the rest, so your looking at about 385 watts under a full load.
Edit for future proofing that is up to you.
Also depends if you're gonna OC it
750W is sufficient enough, but given the state of crypto mining where PSU supply may have been affected, its not a bad choice to also go for 800W or higher, which also gives you some more headroom. Cryptominers buy PSUs too.
So 750W if you can get it, or go for higher wattage whichever is available.
I had a 2070super an i9 9900k. It ran on a Seasonic Focus gold 80+ gold for a year and a half. I used that psu for the 3070 about 2 weeks also before i got a new psu. If i am not mistaken the 3060ti has 600w as recomended psu. So yeah your good
