I can get an evga 660ti used for $160 or a evga 670 ftw bnib for 300$. Which would you go for. The 660ti is the better deal obviously which makes ithard to pay tthatmuch more for little performance , what you guys think?
I have a 660ti,and I am happy with its performance, I can max nearly anythingI throw at it. However I play on a 20" widescreen @ 1440x900 res.
In a way, I wish I would have gotten a 670 because, price per performance, I think they are the best card available.
In your case, I would get the 660ti, and see if it satisfies you because it is such a good deal. If you would rather have a 670 after trying it, you will be able to get more than $160 for it on ebay!!! Probably closer to $240 used
Well I will be putting it on water and over clocked looks like the 660 ti is just a few frames behind and for $140 less looks like 660ti it is and if I'm not happy I can sell it for more just like the other guy said.
He is aallowing me to test the card before I purchase, I wouldn't of considered it otherwise for $160 but he is being very helpful and allowing me to test so it sound pretty legit just going to bring a spare rig and monitor and run fur mark on it
Also my spare rig has a thermal take tr 450watt psu with only one six pin adapter should I not risk using that power supply to test it's pretty old but my other rig has a full water cooling loop so makes it hard
