Question 6750xt Speedster temperature / fan question
steveylee
14
Hey all, i have recently purchased a 6750xt speedster and i am just wanting to be sure there arent any faults before i staart gaming on it. I noticed that when i launched word or warcraft the fans werent running on the GPU. Does anyone know if the speedster has a temperature threshold as to when the fans turn on?
Thanks in advance
How are you monitoring the temps on your GPU? Does the GPU's fan turn up when you're taxing the system with another title? On second thoughts, please pass on the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
If you've performed a GPU upgrade, did you use DDU to remove the prior GPU's drivers before you dropped in the new GPU to install the latest GPU drivers in an elevated command?
