7.1 surround sound so weird
Hi,
Under your Headphone/Speaker Properties in windows there is an Advanced tab. Under there see if you can change your setting to 24bit 48000.
Another thing you can try is to reboot the PC after the robotic sound occurs and see if it still happens. The robotic effect generally happens when there is a bit rate issue.
see if that helps,
Gabor
all only 16bit 48000 44100 and 96000
