Question 7 fans connected to 1 system fan port?
Jan 3, 2024
8
Hi everyone!
I'm currently building a PC. The PC has 7 fans and I bought an PWM controller to control them all. I'm using the MSI B760 GAMING PLUS WIFI motherboard.
I wanted to know if I can connect the controller directly to a system fan port on the motherboard or if it's to much power for just 1 system fan port.
If 7 fans in 1 system fan port is too much, how many can I connect in a single port? (the motherboard doesn't have 7 system fan ports, only 5)
Each fan is rated for 12 volts.
Here is the motherboards manual in case someone wants to take a look:
https://download.msi.com/archive/mnu_exe/mb/B760GAMINGPLUSWIFI.pdf
Thanks for the help!
I believe that each fan will draw a certain number of volts and the total should not exceed 12v for one port. I am curious to know also and have researched somewhat for my own build. I decided to use a single y cable for two fans sharing one port. Does your pwm controller need to connect direct to the board?
Reactions: machadinhos
The controller has a PWM cable to connect somewhere...so I assume yes.
