78lmt-usb3 r2 xp 32 install problems
graydust153
Commendable
Apr 4, 2018
73
All the components I bought supports xp. The first problem is when I try to install xp it will blue screen with a 0x0000007b code. Iv tried putting it in ide mode but still crashes. I tried doing the install on a different pc and moving the hdd to it. And it worked but I was having trouble with driver install for the gpu.
Any idea on why I can’t get the installer to work on the 8350 with a old ide hdd and also before it blue screens the i here fans ramping up. But windows 10 works fine no problems
Also on the site the mb has xp32 nit drivers but on the website for nvidia I only see it says xp and xp 64 is the download for xp drivers without the 64 at the end a 32 bit one it’s not stated when I go to install is seams like it’s gonna work the says something about net framework
The pc specks
78lmt-usb3 r2
8350
Hyper t4 cooler
Gtx 780 also tested a 550ti
2x4gb ram also tried 1 4gb stick
80gb ide hdd
1000w seasonic psu
The 0x0000007b error related to the device driver issues, data corruption, hardware Issues. https://support.microsoft.com/en-us/help/324103/advanced-troubleshooting-for-stop-error-code-0x0000007b-inaccessible-b
So make sure your ide hard drive jumper settings is right, master is for boot drive. Double check the ide mode in the BIOS, I know you tried that. Also read that article the "General Troubleshooting" section to see you can fix it or not.
The ide jumper will depend on what brand you got, it look like similar to this: https://www.datarecoveryunion.com/images/2010/06/image_thumb8.png
For the GPU driver, the one without 64-bit at the end is the 32-bit version. Also you need to install the newer net framework too, otherwise you can't install the GPU driver.
https://en.wikipedia.org/wiki/.NET_Framework
The one Pc was fine with no jumpers set on the hdd any reason the 8350 would then also on nvidia they only show 2 downloads they have one with xp no comment on 32 or 64 and they have a second that says 64 at the back
