Hey guys, I've had my computer for about 7 years now, and in that time I've followed the scene a bit less each year. I'm starting to have a little trouble (lower framerates) with some of the more recent games that come out, and doing multiple things at the same time while on my computer. Here's my problem:
Nothing is breaking, but things are starting to slow down and I can't put graphic settings on high and ultra like I used to be able to. I also do work on this computer in programs like AutoCad, Rhino, the Adobe suite, and ArcGIS on occasion (possibly City Engine in the future). I can't really afford to upgrade everything right now, so I'm planning on doing it in steps.
My setup currently:
Intel Core i7 920 (2.66GHz)
asus P6T Deluxe (intel x58 chipset)
8GB DDR3 RAM
Samsung SSD/ WD HDD
I'm currently pushing to 2 screens: A 2007 Toshiba regza (30-ish inches) at 1080p, and some old Dell Monitor at 1024 (19in).
[I would like to replace the TV at some point probably with a 27" LCD monitor with a higher refresh rate than 60, if that makes a difference]
So I know that at some point, the CPU/Mobo and GPU will need to be upgraded. I have a 750w psu that I'm comfortable with so I'm not worried about that. The RAM can also come whenever, as it's relatively cheap.
I'm basically asking what order should I upgrade things, and could you guys give some suggestions? I checked out some reviews/guides and the Radeon 270x seems pretty decent for its price. As for the CPU, I have no idea, except I'm guessing that I will have to get a new motherboard with that as well. I'm not beholden to any company, so pretty much any suggestion would be welcomed! Also if I'm thinking about this wrong please let me know. Thanks in advance!
My setup currently:
8GB DDR3 RAM
Samsung SSD/ WD HDD
