8.1 hard reset required when stuck in sleep mode
blahcomp222
186
what a disgrace of a product, they should be jailed for this OS, endless careless errors this OS has that they pumped out quick to get into the tablet market. They should pay me to use this instead of THE RICHEST MAN IN THE WORLD behind behind this product.
it's simply a product, not some magical thing they think they're doing us such a favor with. people love their computers so much, they basically disregard how messed up this OS is and have to constantly jump through hoops to get things working. It's like buying a car and then nothing works and you have to spend 6 hours researching that to get it to work you have to put it neutral for 3 seconds, tap the dash board 4 times, then turn the radio to 96AM, then start it. Then something new breaks in a couple weeks.
the current problem: I have it set to automatically log me out after ten minutes. If I leave the computer for ten minutes, the screen goes black and I hit spacebar and have to enter my password to get into explore, which is what I want. It worked fine for months, then started not waking up when I hit space bar or anything else. I could tap my power button on my PC case and wake it up sometimes, but sometimes all I can do is hold down power and restart the PC and it takes like 3 days to boot up again. A few days ago, I spent a few hours of my time researching how so many others had a similar problem and went in all the settings and changed things around a little. It's how it should be and was waking up and asking for the password which I wanted, but now it's back to requiring me to hard reset it to wake it up.
and also, how do i make it not pause a spybott/defender scan while sleeping or whatever it's called it's doing when the PC locks out after 10 mins I set it to do?
found a sort of trick to bypass this, for me anyway, when the Pc is sleeping and I press any key, the log-in screen shows. I must log in that first chance, otherwise it will go back to sleep and never wake up forcing a hard reset. Good program, made by smart people.
oh man, I am having the same stupid problem and you are so right. you spend hours/days trying to figure this crap out, I can't stand it. I tried logging on but still had a black screen. I actually seen that I was going into sleep mode for 6 days! wtf?? anyway, I'm done trying to fix it. Win8 is hard enough to get around. Right now I'm "refreshing" my laptop. Next step, go back to factory defaults. hate, hate, hate windows 8
