8 pin and 4 pin of asus rog crosshair vii hero (wifi)do i need to plug in both to psu?
May 23, 2018
i bought a asus rog crosshair vii hero (wifi)..my problem is there are 8pin and 4pin on the motherboard and my PSU can only accomodate 8pin....so will that be enough?or i need to buy a new PSU that have a extra slot for cpu pin?
im not into Oc ...by the way my proc is ryzen 2700x
A 4-pin and 8-pin connector to power that processor of yours, just using the 8-pin connector is plenty though, in fact using just one 4-pin would do the job already.
The 4 pin connector is an auxiliary power connector that can help provide more power for the CPU, not required, and nothing will be damaged if you use it or not. Extra 4 pin is mainly used by LN2 overclockers.
Reference: ASUS ROG Crosshair VII HERO (Wifi) review >> http://www.guru3d.com/articles-pages/asus-rog-crosshair-vii-hero-(wifi)-review,5.html
