8 pin cpu power connector problem , psu recommendation and psu advise ( uprading my old pc )
Renzel Hirt
35
hi i currently upgrading my old pc heres the specs
Intel core 2 duo 2.8 ghz
4 gb ddr2 800 mhz
1 tb hdd wd blue
hd 7770 1 gb ghz edittion
500 watts hunkey psu
im planning to replace the BOARD, RAM AND CPU
AMD Kaveri A10-7700k
Gigabyte GA-F2A88XM-HD3
Corsair Vengeance 8GB Single 1600 CL9
PROBLEM : My old psu dont have 8 pin cpu power connector , i noticed that the board required an 8 pin 4 the cpu i check the psu i notice that the psu have a 2 pcs of 4 pin cpu power connector with labeled "P4" and the other one is just plain connector maybe for amd processor .. this is the picture
or maybe i can combined this two 4 pin to make it 8 pin for my new motherboard ????
and
thanks badly needed your help because im short in budget right now i cant afford a new psu....
Normally a single 4 pin in the CPU 8 pin slot is enough, if you don't OC that is.
The components you listed are all compatible and are good choices for components, though why are you getting an APU CPU if you have a 7770, your better off getting a FX 6300 6 core CPU socket AM3+ and a ASRock 990FX Pro3.
Later on please upgrade that PSU as it is not a very good PSU, but for now it should be ok.
@unknownofprob hi there i update the parts and i consider your suggest
AMD Vishera FX-6300 3.50GHz
ASRock 990FX Extreme3
this is what i will get can you recommend a psu?? i will just overclock a bit may bee 4.0 ghz 0r 4.2 using my old T2 BLIZZARD CPU COOLER
nope i was referring to my old psu "huntkey 500 watts" is it ok i use? 2 pin so i can overclock a bit?
or better get a decent psu then overclock my system
ahh ok i will not overclock for now.. can i use the two 4 pin??? for cpu power?
